Mineallmine
I have been reading on torsion bar adjustment and have been finding conflicting answers on one part that I am trying to understand.
A lot of people say when adjusting ride height make sure to loosen the front nut on the lower control arm pin. I can't see why this is necessary. When you are adjusting the ride height the torsion bar (and pin) aren't actually being turned. When I had it apart the torsion bar moves directly with the pin, loose in the control arm, only stopping when it hits the adjustment bolt. I fully get not tightening the nut until the weight of the car is on the suspension as that's when the torsion bar is loaded up. If you adjust the lower control arm up or down, you are only moving the lower control arm, not the torsion bar itself. The amount of load on the torsion bar is exactly the same.
I do also get that it will require an alignment after as it will change the camber.
Just trying to clarify what I understand and have researched. You aren't actually changing the load on the torsion bar, just where the load starts being applied, thus the car will have the same load no matter what, just the control arm itself will sit either higher or lower due to it contacting the torsion bar arm (where the adjustment bolt contacts) earlier or later depending on if you are raising or lowering.
If there's something I'm missing please let me know.
