ESP47
Will a 68 Barracuda fastback door go on a 67 fastback chassis no problem? Just want to make sure there aren't any huge differences before I pick it up. Thanks!
Thanks, this is a passenger side door so the mirror is no problem but the arm rest and vent difference are deal killers for me. Good info, thank you sir.
You are very welcome.
You can get around both issues unless you just want a bolt on and go door.
Wonder if the lock/handle linkage is the same? They were different on the 68 to 69....at least on the Dart....
Honestly I was just trying to get around doing some body work since the body line on the door is dented up in a couple spots. I'm guessing either one will take the same amount of work so I'll just have to stick with what I got unless a 67 door pops up around here.
This is what I ran into on my car.They are the same on the 67 and 68. In 69 the door knob lock was moved and I have seen a different latch mechanism on the 69s.
