Moparlover---Explain the half the cost post?????? Cost on a 600hp motor???? No way it would be half--Unless of course your using 440 source stuff and I would like to talk to someone who is using 440 source stuff on a dedicated strip car--Steve
x2 this ^^^^^if it was me - and i hope to be in the same palce ina few years in terms of building something for myself - i'd go 4 link. You're starting from a clean slate. Imo - go the full monte with what you can do and back half it. You will save money on the powertrain by getting an adjustable chassis and less weight behind it - and ultimately leave yourself room to grow in the engine department. As far as the cage and stuff- if it's a race car purpose built - do it from moly from the get-go. It's cheaper than doing it in steel and then wanting to upgrade later.
I should have stated also this isn't your dream drag car but building on a budget
Since your talking rear suspensions and budgets, for long term durability, you may want to consider housing choices while you're at it. 10 oh's is approaching, a back braced/fabbed 8 3/4, Dana 60, or even 9" Ferd territory.
