Barrycuda
Mopar Maniac Guru
is a 22 inch rad the correct rad for 70 dart with 340 ?
thanks for any replies
It would be a 22" but not all 22" radiators are created equal.
huh?????
Just because it is 22" doesn't mean it will fit and work correctly. There is a correct amount of tubes as well as a thickness for a 340 to cool it. There are height differences on some radiators too. There are hose connections in different locations depending on the water pump outlet.
ok I will check for all of the above thanks
