Random pictures thread
If the top looked like the hood.....and retracted like that.....
Found these old recalls for I believe 1968 Barracudas
Recall
Component
SUSPENSION:FRONT:CONTROL ARM:LOWER ARM
Manufacturer
CHRYSLER CORPORATION
NHTSA Campaign ID 67V121000
Notes POSSIBLE INCORRECT LEFT LOWER CONTROL ARM IN THE FRONT SUSPENSION ASSEMBLY.IF THIS CONDITION EXISTS, IT IS UNLIKELY FRONT SUSPENSION ALIGNMENT COULD BE SET TO SPECIFICATIONS.THIS COULD RESULT IN POOR DIRECTION- AL STABILITY.ALSO, THE INCORRECT CONTROL ARM MAY CAUSE DAMAGE TO BRAKE, STEERING AND FRONT SUSPEN- SION PARTS.(INSPECT AND REPLACE THE LEFT LOWER CONTROL ARM AS NECESSARY.)
Component
POWER TRAIN:AUTOMATIC TRANSMISSION
Manufacturer
NHTSA Campaign ID 67V072000
Notes POSSIBLE INTERFERENCE BETWEEN THE FLOOR PAN AND THE TRANSMISSION KICKDOWN ROD.THIS CONDITION COULD RESULT IN FAILURE OF THE THROTTLE TO RETURN TO IDLE.(INSPECT AND REWORK TRANSMISSION LEVER.)
Component
SUSPENSION:FRONT:CONTROL ARM:UPPER BALL JOINT
Manufacturer
Mfr Report Date 19680301
NHTSA Campaign ID 68V025000
Notes POSSIBILITY FRONT SUSPENSION UPPER BALL JOINTS MAY NOT MEET SPECIFICATIONS.SEVERE IMPACT ON SUS- PENSION SYSTEM COULD CAUSE UPPER BALL JOINT TO FAIL AND CAUSE ERRATIC STEERING CONTROL.(CORRECT BY RE- PLACEMENT WHEN NECESSARY).
Information provided by NHTSA
3 Recallsfor 1968 PLYMOUTH BARRACUDA
FILTER RECALLS BY AFFECTED COMPONENTS
All (3)POWER TRAIN (1)SUSPENSION (2)
March 25, 1968 NHTSA CAMPAIGN NUMBER: 68V025000
SUSPENSION:INDEPENDENT FRONT CONTROL ARM UPPER:BAL
September 12, 1967 NHTSA CAMPAIGN NUMBER: 67V072000
POWER TRAIN:TRANSMISSION:AUTOMATIC
December 18, 1967 NHTSA CAMPAIGN NUMBER: 67V121000
SUSPENSION:INDEPENDENT FRONT CONTROL ARM:LOWER
Saw this at the drug store yesterday. I went inside and found a guy wearing a nitro t-shirt, and figured he was the guy. Had a good conversation while standing in line. He says it's a true 440 4 speed track pack car. He also said it cost him more than his divorce.
That’s awesome how your educated guess turned out to be accurate!
This guy flew into my family room window an hour ago. Brown hawk. He was knocked out cold but breathing. He finally woke up and is standing now. Still groggy. Watching to see if he is OK or injured as one wing does not look quite right so far.
We get about 1 bird every 6-9 months that do this. One time a Canadian goose did it. Talk about a THUD when he hit! He was out a long time but finally woke up, stood around a while, then flew off. Probably had a bad headache!! I'm glad that so far, these Anderson double pane windows are holding up to the hits!!
EDIT: After about 3 hours, he was up and has flown away!
But I will bet it was worth it!
