That bulge scoop looks a tad wider than 28" at the front which is what the Duster hood's "rise" is which also gets progressively wider and shallower the farther back on the hood you go. The angles on the leading edge look very similar to my cowl scoop which are off an inch or two from the Dusters flatter angle. Definitely has potential and I wish I had included it in my research before purchasing my current scoop. Of course an original Mopar scoop assy would probably cost the equivalent of a small yacht. I'll have to make that cowl scoop look good and be functional at the same time or it will go bye bye.
Progress report: Wiring is now complete from the altenator to the Ford starter and continuous duty relays in the back seat. All that's left is routing to the battery and the cutoff switch and their hookups. I know more boring electrical work. Not much visually exciting here but every wire done represents hours and hours of routing, cutting, soldering, heat shrinking and last but not least - thought. Since these photos were taken I rerouted the black 4 ga. cable on the left to follow the other cables on that side.
A new Voltage Regulator, purchased at MATS a few years ago, is also adorning the passenger's inner fender.
The pulley's are a March serpentine set up, got tired of tossing the v-belt everytime I revved the engine.
