Lonewolf3165
Living the Dream!
LOL!! - Very good advice!..don't drop them.....
Yes, my car has molding clips for the stainless steel trim around the windows
I had a professional come to my house for my 76. We tried roping it in with no success. He left and I was frustrated, so later that evening I tried popping the gasket on the car, then laying the glass into it (working around it slowly with a plastic glass tool.) i did put some adhesive in places , but used it very sparingly. thats how I installed mine. I had never done it before and found it to be a miserable job, but I was happy to finally have it done.
that would tell me they dont wont to or know whow to find another co. or try it your self..........ArtieI have new molding clips and new gaskets. I spoke with one local glass company and they will install it but no liability for leaks or broken glass. So I figured I might as well do it myself. Plus they put a high quote on it, in my opinion to deter me away.
i worked in an auto glass shop also. i think the key to roping glass in is to have a well lubricated rope, not dripping wet but oily enough to not get hung-up on anything when pulling the rope. having said that, roping should be fairly easy with the front glass since there aren't any really sharp corners to go around. not so easy with the back however. i roped in my valiant backlite the first time and it was a real *****, even tore the gasket in one spot. the dart's backlite has an even sharper corner (the bottom corners). the next time i used the plastic paddles for the install and it went very well, not easy, but easier than roping and a bit more time consuming. -pauly
If you have chrome trim, make sure you use all new clip fasteners.
Don't use the rope-in method, it works for some cars but isn't easy or nessessary on A-bodies.
Get a couple of these install sticks, place the gasket in car first, then place the glass in the lower gasket channel and carefully work the glass into the remainder of the gasket with the sticks. use a little spit if you want to make it a little easier to draw the tools through the gasket/glass.
Use a small bead of windshield sealer on the gasket/pinchweld joint if you must, making sure you only seal the top and sides. leave the bottom alone, if water does get in there it needs a place to get out.
Method is the same for front and back.
http://www.ebay.com/itm/Windshield-..._Automotive_Tools&hash=item5647e9c22c&vxp=mtr
