blue missile
Here is the next step at the back of the cockpit.
Addressing the issue of safety:
When I did the minitub I also set it up for a rear firewall composed of two sheets of metal with 3M 'Firestop" insulation between them. After I raise the tranny/ driveshaft tunnel, I will replace all the temp sheet metal screws ( poor mans cliko pins) with pop rivets. All penetrations through the wall will be in bulkhead connectors with intumesent caulking around the wires. I will also be putting sheet metal behind the sail panels to close off those openings as well as making cans for the speaker locations.
Andrew
Andrew
