Richard Sweet
George, Wrong thread reply?
That's pretty George. What brand of exhaust? TTI?It is crazy, I don't like headers at all. Way more engine bay heat, noise in the engine compartment transferring to the interior of the car. Not to mention what a pain they are to put on and work around, always in the way for everything.
We are doing the street cars here. Back when I was a kid a guy put headers on his Roadrunner, it slowed his car down so he put the stock manifolds back on and he was good to go again.
I am sure there are plenty of people that love the headers for various reasons. My thinking to avoid the headers is to let the hot compressed exhaust gasses come out of the heads and through the manifolds, (where they are still compressed yet). Then dump those hot exhaust gasses into a 2 1/2 inch exhaust system all the way to the back of the car. The hot gasses are expanding the full length of the exhaust system creating a suction to help pull spent gasses out of the engine.
Just my thinking here, others will differ for sure. We have an exhaust system here on the 318 302 Heads with stock manifolds, that what can I say, just flat out performs. You can make up you own mind on how you would like to do things.
Just like the flame of this rocket expanding it's exhaust gasses after they leave the main rocket engine. The expanding flame pretty much dwarfs the size of the rocket it'self.
View attachment 1715394260 View attachment 1715394267
However you want to build your projects is fine with me. It's all pretty specific for your desired outcome and how the car is going to be used in the end.
Happy Motoring . . .
I need exhaust on my Swinger and have a pair of 68 340 manifolds on the shelf. I like the Dynomax sound.Yes TTI
Nice fitting package, snaking around the torsions up at the front, and the X-Pipe design to get the alternating pulses from side to side to help pull out the spent exhaust gases. Dynomax Mufflers, it had flowmasters but too much drone and ting ting ting . . had to come off.
How do they look?Received the two 2D31 Famous Brand cylinder heads yesterday from Rock Auto in Houston. They were remanufactured in Mexico. Casting #4323302 on both & they look ok.
Regarding the heat buttons, if they melt at 265*F, it would be best not to cure any VHT paint applied to them in an oven, as instructed on the cans: first at 250*F, then at 400*F, then at 600*F. It would be better to wait 7 days, then cure the painted heads on the engine, as instructed. Dupli-Color engine enamel with ceramic spray cans instructions don't specify any baking or curing, so maybe that would be a better choice.
302 heads require less timing which is their biggest advantage. Back when they first appeared where advertised as 'fast burn' similar to Chevy Vortec.Bigger ports than the 318s from the 60s-70s. But yet still a 318 casting.
They have the same size ports as any 318 head. There is no difference between them other than the closed chamber...and that aside from raising the compression a tad will only benefit you if the piston is close enough .050-.030 from the closed side of the chamber to achieve quench effect.302 heads require less timing which is their biggest advantage. Back when they first appeared where advertised as 'fast burn' similar to Chevy Vortec.
Dang George,That is really good info and makes perfect sense. First time I had heard that angle on the 302 heads. It just keeps getting better and better. Thanks for posting that up !
Dang George,
Check it out...any closed chamber head takes less timing than an open chamber because with an open chamber=more area=needs earlier ignition to burn it in the same amount of time . Flame travel . A to b , now shorten the distance, hence fast burn. When they say fast burn, that's because the chamber is smaller, more compact, less distance to the plug everything's being shoved towards.
It is not a bad idea to check it, but honestly, for a mild rebuild like your 318, it is easy enough to compute it and it will be within a few thousandths + or -. You just add half the stroke to the standard rod length to the compression height of the piston and subtract all that from the standard deck height.I believe there was one pair left when I bought mine last night.
Thanks for the info, I'm currently rebuilding my 318 and haven't yet begun to put it back together. I have the bare block back from the machine shop, new pistons, crankshaft, etc. I've gotten some cam suggestions here on FABO, but do you still recommend finding my deck clearance before selecting a cam?
Boy, that is a hard call to make. Thye ought to be rebuilds, but it's hard to say where they were rebuilt and so hard to say what can be good/bad/indifferent about them. Let's just hope any seats are set in better than the last set! I can see going either way here: run with them and keep your fingers crossed or have then checked over..Just ordered mine. Will I need to take them in and have them inspected, or are these ready to go?
BTW as for cam selection, do you want to run with the valve springs that will come on these heads? Which are very likely just simple stockers. This seems like a project to build just a solid, reliable basic engine with part off of the shelf.
It is a classic issue for 318's: the low CR limits you on cam for daily driving. If you over cam it is sluggish at low RPM's. If you are drag racing, you put in a high stall speed TC, rev it past the low RPM's before launch, and don't look back. Not the same for street driving.It’s a tough call regarding cams, part of me wants to be conservative and stick with the simple (and reliable) build originally planned, but the devil on my shoulder wants to add just a little here and a little there.
