RandyB
Just got home! Puppy first, sorryOk now we need puppy pictures as well.
Do not ask how much she spent on this purebred Beardie Collie cost pleaseAwe that is a damn cute little pooch.
She got here in one piece! Thank you Mike!Awe that is a damn cute little pooch.
Yep, Wisconsin has some nasty wintersLooks like you got the throttle adapter too.
...and a choke. That might come in handy in WI.
My car needs the choke, even in 90+ degree FL.[/QUOTE
WOWSER
Sorry but with the new puppy training work 50 hours a week, plans for a 2 1/2 car garage in the works, new flooring for kitchen, living room AND dinning room. I’ve only started to clean up the carburetor. Still have to get the transmission back in, intake and valve covers to clean up and repaint, And a ton of other stuff before I can get it running. But life is good!@RandyB any updates? Is the car running yet?
Roger that Sir!Sounds like a full plate. Know how you feel. I added a boat to my project list recently because I needed more stuff to work on (nope) and put everything else on hold. But you’re correct life is good. Keep us in the loop when you get to it.
That’s what it looked like. But got in it really good. And by the way, I STILL have to get you the cash for shipping. Which is top of the list, I didn’t want you to think I forgottenNice work. Glad you’re finally getting some time to work on it. From the pics it looks like there was some crud in the bowls. Hopefully you got that all cleaned up. It’s probably leftover crap from my hot tank.
Yup! I guess I will do it right this time, Picking up some compressed air and a better brunch to redo it. I’m just always in such a damn rush getting things done. I’d rather do it now than have to take it off and redo it after finding out something is plugged because of my inattentive natureThat looks like a lot of corrosion.
Soak and scrub.
Ugh.
I'd blow air/cleaner through the passages, esp the pump squirters.
We used to rebuild carbs in the back room at the speed shop I managed back in the day. 500 2 barrel Holleys can be taken apart in about 5 min.Do you think they rebuild carburetors in the back room at O'Reilly?
