I smell what ur stepping in. This just happened to be how they designed it.
LS Low Mount Alternator Bracket for Electric Water Pump w/ Tensioner Compatible with Camaro LS1
agreed, a lot more belt wrap on both the crank' and the alternator with their routing. much less likely to slip.Looks like your belt routing is a little different from what they show:
Oh **** yeah good catch, thank you. I'll have to fix that. Must have been one of them rough/long nights.Looks like your belt routing is a little different from what they show:
That debate has been ongoing internally for a while now.....Hell yeah man! It's comin right along. Lemmie ask you, do you have any plans to decorate the top of the intake? It's a blank slate.
Man im special. This thing is frying my brain. Gonna give it a **** this way. If not then I'll switch it up and see. I ought to have just taken the picture out there with me. I looked at it and said, yep that looks better. My brain will catch up one of these days. It cant be any worse than before though. Thanks.Your belt routing is how I suggested it in post 1476 but it is still different than the pictures in the link you posted.
We’re all special in our own way.Man im special. This thing is frying my brain. Gonna give it a **** this way. If not then I'll switch it up and see. I ought to have just taken the picture out there with me. I looked at it and said, yep that looks better. My brain will catch up one of these days. It cant be any worse than before though. Thanks.
I haven't scrubed it down yet to look for the crack. But I will be looking after dyno is over with.What was the issue with the flexplate? Was it cracked?
