Red Headed Stepchild-75 Swinger LSX Swap
Everything js all wrapped up. But when priming the fuel system today one of the old flexible 90 degree fittings failed gling into the fuel rail so I had to order a few new ones. Should be here tomorrow and then first light off on the new setup.
What intake is that? That’s a killer piece with the intercooler integrated in to it.
This one was hand made off his own 3.5" core. By Wes Chadwick of Chadwick Racear fab. More than half what they charge at the big boy shops and just as efficient up to 2k hp.
It's setup to work well with my 3800-4200 rpm typical leave and they expect it to flash in the high 5k range on this setup.
Cool. DO you have it tight enough to drive to the ice cream store?
Tuned up enough for a trip to tractor supply and putting the grocery store on the way home.
Today also commemorates 9 yrs since I bought her back in 2015.
Have been doing some driving to give the computer some time to learn and go through the motions on all the new upgrades. But we're making tuning adjustments snd incentives wait to hit the track.
Went out to the highschool today, oreillys otw home and all.
Random test I did today to help a fellow enthusiast who was fender dump twin turbo swapping his Dart. 86db on average cruising down the highway.
Latest update, I've been driving her around town putting some miles on her and when i was doing some more driveline stressing, I had a intermittent cam/crank sync error pop back up. After pulling some shielding snd trying to repeat the fault while I manipulate the harness, I was unable to get the fault to repeat. So I have a 12-1 external crank trigger I got installed yesterday. Have to pull the plug to verify were really at TDC the correct way, then I'll throw the charge pipe back on, load the tuneup and fire jt up to see if I can get it to repeat out on the road. But can't do they until it stops raining.
I also have a HCR innovations harness coming because I've long suspected the holley harness has been the culprit. So if this 12-1 crank trigger doesn't fix the issue I'll just sell that setup and the her innovations harness is already being built and will be here very quickly after.
Got the new harness setup in the mail from HCR innovations. And got thr holley harness ripped out yesterday.
Then Got it 98% installed today to get ready for the track rental on Wednesday.
Well we had our first outing of 2024. First pass after a completely stripped track in the off-season, i was a little too hot on the leave first pass. So I blew the tires off on the leave during pass 1.
Found a crack in my co2 line during pass 2, and ran a 10.1 on wastegate only. Leaving on 2.5 psi of boost pressure at the line snd 5 psi down track. I fixed that issue snd then during pass 3 the dome pressure **** the bed during the burnout and I made another wastegate only pass and went 9.8 on only 5psi of boost.
Now test I've fixed that I cant wait to start making passes under boost soon.
Good morning everyone. I have the dome pressure sensor issues all fixed up and I'm going to be installing the new cam and crankshaft sensor one last time to see if I can get her to play nice before having to do something more invasive.
I'll be attending a roll race event May 18th at Bremerton raceqay with some of those 1/4 to 1/2 million dollar high end exotics and GTR's, so we will see how that goes. Been what amount to an airstrip with bo real traction areas other than right ay the beginning, the new traction control on the dart ought to help. I've never experienced that before so it should be interesting.
I also have the Olympic Drag and drive scheduled to start at Bremerton on May 31stthrough June 2nd. That will also be a first but a good test of the streetability of the car with the drag, swap tires and then driving all day and then racing again on Sunday. So that should be fun.
Made it to my first roll race. I always thought jt was kind of dumb, but definitely enjoyed this experience despite the exhaust Leak limiting me to 8psi. The only races I could get were against built street bikes. This one was against a built kawasaki H2.
Had some fun during the event and definitely needed more than 8psi on that bike. I'll be attending their next one July 20-21 to try it out again.
Still going next weekend the May 31- June 2nd for the Olympic Drag and Drive. Just got her fired up on the 92 octane tune today and when weather is nice Monday I'll be driving it around to do some more learning in the computer.
