It will work fine = We have it on both our 10 Sec. Street Valiants.
However, it is a bit noisy of adjusted properly.
It will be fine. The avatar has that setup with the split mono springs. Noisy? Mine make a noise on part throttle 2-3 shifts on the street but that's all I ever hear. Deep throttle, the engine is LOUD so you don't hear anything from the suspension!Going to call Calvert Racing in the morning and check into a mono-leaf setup with caltracs.
Not too sure about how it will behave on the street.
I have a 72 dart setup identical to what you are talking about, dana 60 moved back 1.25, caltrac setup with sliders etc. I drive it a ton on the street and a fair amount on the freeway and I can say I think it drives better than it did with all the stock stuff. Is your car painted green go?, that's what color mine is.Going to call Calvert Racing in the morning and check into a mono-leaf setup with caltracs.
I'm glad to hear this @GTX JOHN ! I've always thought the 2-3 shift CalTrac noise was just my car. I also have a RMVB but mine is a name you'll probably recall from the past: Griner. It's in my Cope 727 trans. Low band apply, etc, etc. It's a keeper for sure!!All of ours make a loud clunking noise when shifting gears
especially 2 to 3.
We leave in a small town where everybody know us, so we
are only at full throttle at the Track.
We have Pro Trans reverse Valvebodies that shift hard, that
probably aggravates to clunking compared to a stock transmission.
