That's a nice one. Canton makes some high quality stuff.Canton makes one also #22-595
22-595 Alum Remote Oil Filter Adapter For Ford and Mopar 90 Deg Rotating
Thanks for the reply. Didn't that location create a dry start issue, since it's above the original filter location?In Australia all our A body V8s used a remote oil filter set up from the factory as an oil filter in the stock location would be were our steering box is located. A plate is used at the oil filter location with pipes taking it to a reote filter at the back of the motor next to the distributor. This is a very messy system so on my cars I have always used braided lines going forward to the right hand side inner guard! Someone in Australia also makes a nice billet alloy plate with fittings and that is what I use as the cast iron plate is subject to cracking if you overtighten it! sorry but I do not have any images of it.
No there is drain back valve somewere in there and my car can sit for weeks and within two seconds of starting has great oil pressure!Thanks for the reply. Didn't that location create a dry start issue, since it's above the original filter location?
You can also move the filter where it is away from the exhaust/headers. I have my oil filters remotely mounted but my application is drag race only.
