UOP
Got a minor problem. Spent the day upgrading my fuel system by installing a new fuel pump and fuel pressure regulator. For those who don't know this is in a sbm swapped RX7. The problem is that the FPR will not regulate the fuel down past 7.5 psi, instead of the 6 psi I want. I'm thinking that my ~5/16" return line is too small for the fuel pump I'm using (255 lph). So next weekend I'm going to upgrade the return line, but I'm not sure if whether or not upping the size to 3/8" will do the trick. Don't want to spend the time and money if it won't work so I figured I'd ask. Anybody have any experience with kind of thing? I need to get this worked out.
Thanks
Thanks
