RHS flow #'s
Hey Guys,
can anybody tell me which Headbolts you are using with the RHS-Heads?
Tryed to install them today without success!! The original ones are too short.
Only the 2 long Bolts fit, but i need them for all the holes IN the Head.
on the outside the small ones fit, but IN the Head they are too short.
Measured the depth off Head mounted is all holes 4,8" deep.
But i can´t find some screws who fits....
HELP! :(
Hey Guys,
HELP! :(
Speak to Brian...there is a set of bolts that there might already be an ARP part number for, but I think he still has a few sets laying around last time I spoke to him.
I'm gonna need them too, but I'm not there yet.
Hey Guys,
HELP! :(
Yes, Brian has them! I bought a set from him for my RHS Heads.
Ok, thanks guys. The only thing i don´t know is...who is Brian?
I think i just need the Partnumber, because i´m in Germany and it will cost to much to ship them and needs to long:-D
But maybe i can get them by our local dealer!
I can ship to germany just need address & payment. They are 95.00 plus shipping.
Arp might have some in stock now but we only finalized this 2 weeks ago so I doubt a dealer would have them this quick.
Brian
Brian
Brian do the RHS heads take different bolts than the EQ heads? I thought they'd be the same, but maybe I'm wrong. I bought ARP bolts for magnum heads and they fit the EQ heads fine.
The RHS Heads take 2 size bolts or studs only. The bolts or studs outside the valve cover are standard. The ones under the valve cover are longer. The studs I used on the 410 RHS Heads are 5.75" long. Bolts used under the cover would most likely be a little shorter than that. I would guess at 5.50" long with the washer used. I have a set of ARP bolts for the RHS Heads in the garage but haven't measured them as of yet.
I haven't measured my bolts but the description sounds the same.
Never bothered to check the EQ heads, but they should be the same as the magnum oem heads.
These RHS heads need shorter long bolts or they can bottom in the block.
The short bolts are all the same.
Brian
Brian
Yeah the Magnum bolts fit fine on my EQ heads.
