Rocker Arm help
I’m going to show you guys some pictures of a new set of Edelbrock heads. They have the exact parting line that I’ve seen on speedmaster heads. Hmmmm
Is it a visual artifact from machining or do the saddles have a "W" shape to them like the SM heads? Any chance on a picture from the side of the saddle with a shaft in the head?
Two year update. After the initial loosening (half torque in under 200mi) they've remained tight since I retorqued in spring 2022.
Not an ideal situation, but it seems sorted out on my end
I check mine every winter and have never found a loose one, although mine have never been loose and I verified my saddles didn't have a high spot in the middle. Car runs low 7.20's in the 1/8th with 273 adjustable rockers on pump gas.
