Not trying to create another "what is the best rocker arm' thread but today I figured out that I have a bit of an issue when I was looking for rocker arms for my 360.
I used to have the stock springs that come with the edlebrock heads, as well a PRW aluminum rocker arms (do NOT recommend them). Well after having my issue with the heads and those rocker arms that ate up the tops of my valve springs, I am going solid roller. The heads were gone through (I put them on ootb, which was a bad idea..) New springs were installed, but the diameter of the springs is 1.525". I originally wanted to go with some Harland Sharp rockers but after looking on the website it says that 1.5" is pretty much max diameter for the springs. So I would probably have to grind a bit off the rocker, which I dont really want to do.
The springs were matched to the cam, I have 260 seat and 543 open pressure. I know comp has the pro magnum rocker arms that are good up to a 1.625 spring diameter, and I assume that they are strong enough? That spring pressure isn't anything too crazy. But are there any others out there that will clear the springs? and if not is anybody running those comp rocker arms?
These are the ones
http://www.summitracing.com/int/parts/cca-1622-16/overview/make/chrysler
These are the ones
