I just picked up a pair of the comp ultra pro magnums, and they are substantially better than my old rockers, the rollers are so much better too! And they clear the springs without issues at all.
But as I was test fitting them I noticed they didnt come with any hold downs, and state in the instructions that they use stamped hold down as require at least 30 thou clearance between them. Are they saying to use the stock rocker arm hold downs? I put them on with those and they make the clearances too tight, do I have to shave some material off of the stock holddowns for them to fit?
On the rockers there is a 1 or a 2 on the bodies, but I cannot tell the difference between them, what do those numbers mean? Because I also dont have to same number of each.
