bamamopar
This maybe a dumb question. But can you use mopar roller lifts with a aftermarket roller cam?
Yes. As long as you are using a Magnum block and the roller camshaft is the Magnum style cam.
How bout the later "roller LA" block?
The small amount of research I did shows the roller lifter part numbers (replacements) are the same for both LA rollers and magnums...
318willrun could probably shed some light on that
Nope. Not even sure that an '89 360 would have a long snout cam.^^^^ see RRR last post ^^^^ I myself am about to put a factory stock LA roller cam from a 89 360 into a '94 318 magnum (so I can run a mechanical fuel pump). I was hoping to use the stock magnum push rods. Anyone know for sure on this swap (done it, no guessing)?????
1985-up 318s (all) were roller blocks- many came with flat tappet cams. I had a late '84 build 318 with 302s, roller cam spider bosses tapped, but it had a flat tappet cam. Cop cars from '85-'89 and trucks '85-'87 were the same way.I know you can take a roller LA block and put non roller lifters in it and have no problems. That's why I was wondering.
I can tell you for sure that the '89 360 cam has the long snout. In fact, when I took the 360 apart, it had a mechanical fuel pump eccentric already on it, but the fuel pump spot was blocked off. This motor came out of an '89 maxi van.
Ahh, speak of the devil and he shall arrive... ;)
As far as the pushrod length, I'm curious on this one as well. You're running mag heads, right?
There seems to be so much controversy on lift and duration of this cam. They say a 318 mag cam is a little hotter than a 360 mag cam, but this is the LA 360 version. I can tell you this, though, that the LA has a 1.5 rocker ratio, and the magnum 1.6. This means whatever the lift is, I will gain approx. .030 more lift due to the rocker ratio.Gotcha-is that 360 roller grind much different than the stock 5.2 magnum?
