AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,840
- Reaction score
- 13,149
Hydraulic lifters have a lot of take-up space. since you aren't complaining about lifter pump up, things must be close enough between the min/max of the lifters. It might not be the best idea, but it seems to be working for you.I sure wouldn't lose sleep over it yet.
According to post#24, you are pretty happy with the engine, so why are you fussing with intakes? Just asking..
An easy way I have found to compare pushrod length is to line them up all side by side,on a flat surface, then slide a straight bar up underneath the tips at about 90* to the shafts. Then the other end will tell the story. Sometimes a second straight edge can be helpful.Their average length can be found by measuring between the bars.This method is quick,easy, and allows you to keep them in order.
