Mine came from Northern Tool and it is a nice cabinet. It is a bit bigger than the one you show, and has plexiglass sides to see into as well. I ended up silicone sealing every edge, seam, crack, opening, and microscopic fissure I could find to keep it from leaking. It was okay with normal media, but when you use the fine beads or baking soda, it finds every hole imaginable. I use it for everything. Guns, toys, even car parts! Cleaning up the leakage sucks, but having the ability to blast your own stuff is worth it. I also have a portable one like the second pic you have. Great to own, but what a God awful mess. I use it for frames and body blasting but put a tarp under the vehicle first to catch the bulk of the media. It is messy. If you own an old car you need them both, though I use the cabinet 90% of the time.
