No bad turns (AKA Curves) with that!
I bet it never gets used due to the cost of everything else that is required to do one correctly. Let's hope a FABO member bought it thou.
Another $2100 and the person will have the perfect set up. Ready to bolt on to the car of their choice.
Those 3 photos. $2800. Hope your sitting down. And that was 5 year ago prices.
Go to Holley.com and check out there prices on there brand new (of course) six pack carbs.
(Be prepped for choke...)
Then find the air cleaner base, top & element.
Check Year One or like places.
(Get ready to puke!)
When you find all the linkages & fuel lines, add it all up!
Check Year One again.
(You may pass out at the total...)
On my set up, I found a place going out of biz selling stuff stupid cheap years back. I added a full intake porting and then powder coated it. It’ll be coupled to a set of Edelbrock CNC’d heads on a .030 over 340 block and a 340 main, 360 stroke forged crank for a min. of 372/373 cubic inches on the final assembly.
It's just money. A good HP intake and single carb combo are well over $1000 new. An MPI fuel injection setup is several thousand to do right and tune. Yeah, you can make the car go down the road with $100 worth of rebuilt junkyard parts, but if you want to have cool stuff it usually costs money. A crusty old AVS on a rusty CI intake isn't too sexy.Those 3 photos. $2800. Hope your sitting down. And that was 5 year ago prices.
i remember that...im still surprised you didnt wake up in a tub of ice with your kidneys missing over that oneI bought mine a couple of months ago complete for less than a grand. So just keep your eyes open and your money saved up.
Pffft, your just poor. $2800 is a drop in the bucket in a car restoration budget.Those 3 photos. $2800. Hope your sitting down. And that was 5 year ago prices.
What it's worth vs what I paid are two different things. Just because I quoted $2800 is not what I paid. I actually bought it for $695 as the pictures show. The ball is in your court. Game on!Pffft, your just poor. $2800 is a drop in the bucket in a car restoration budget.
Hey you’re back! Yet you still haven’t provided any info, aside from bragging again for how much you paid for yours. Shows you only chime in when you can post repetitive photos of your setup yet drop prices on what it would cost implying other folks aren’t a baller like you.
Air cleaner assemblyThank you for the information.
MOPAR - Air Cleaner Assembly Kit — Non-Cold Air
Air filter
Mancini Racing Six Pack Air Filter Element
Center carb - 340
Holley 0-4792 350 CFM Factory Muscle Car Replacement Carburetor
No 340 out board carbs available, use this 440 unit X 2, it is $17 cheaper than the earlier year model. It’s only a jet change in difference;
Holley 0-4672 500 CFM Factory Muscle Car Replacement Carburetor
Throttle linkage
Six Pack Throttle Rods
Throttle return spring
Mancini Racing Six Pack Throttle Return Spring
Throttle return bracket
Mancini Racing Throttle Return Spring Bracket
Throttle bracket
Mancini Racing Throttle Cable Mounting Bracket
Upgraded fuel line in lieu of the smaller diameter OEM
ULTRAPRO Six-Pack Fuel Hose Kit - Poly
Coil bracket
Mancini Racing Six Pack Coil Strap Mounting Bracket
Then add in the intake manifold that is t being made anymore.
If you run a RB (B series is $100 cheaper)
—-> Mancini Racing Six Pack Assembly - 413-440 Engines
No problem, it’s the morning for me (grave yard shift worker) so I had some time to kill. I always say you have to want to do one of these set ups. Don’t let anyone tell you these are impossible to tune, it doesn’t perform as well as a single 4bbl., or any other jive. It is old tech and the way they did things back in the day while under constraints of being a major manufacturer that has to pass emissions, safety and longevity for the public. Seldom does a car/engine package exceed the power of what the aftermarket can provide.
MoPar had the last of the 3 deuce set ups offered as stock. It is arguably the best of them but it is the best street small block package. With this, your just a few parts away from a seriously hot package. Cam, headers and ported heads. As of today’s offerings, ported heads are a click of the button away.
The cost is high. An RPM-AG and a carb to suite is a lot cheaper and just as effective. But lacks the bling, cool factor. Most multiple carb owners (that have there stuff dialed in right!) will tell you they never want to ever go back to a single 4bbl.
A six pack is the most felxable induction system from a mild daily driver to a little wild 11 second runner.
