[WANTED] SB adjuster screw set
Steve, just an FYI, the small blocks never came with lock nuts from the factory. They were interference fit with no additional locknut.
Yep, I already contacted him. I only need the screws/jamnuts tho. I got the last of his NOS rockers.
Gotchya. Just to be clear....are you wanting the factory pieces without the separate locknut? I ask because I have some for the slant 6 and I'm thinkin they might be the same, but I'm not sure.
The 273s did not.
The 340-6 engines did, same adjusting screws and lock nuts as the 426 Hemi.
Steve , do you have the adjusters already ? Is it just your nuts that are missing ?
I have several sets of both but the last time I got a quote for shipping to you it was insane !
BTW did you get that ignition bezel installed ?
Hey Mike, shoot me an email to [email protected] with pics n price. I'm interested.
I havent had an opportunity to install the bezel yet as Cuda has been tucked away for a few years now. Sposed to go pick it up tomorrow tho!
I'm pretty sure what you want are 3/8 thread with a 5/16 ball, hard to find. 3/8 Ball easy to find.
Alan
Thought so. Some will say "no problem, running them for years .." They are not the same strength. The T/A rocker is obviously better. But you don't need them unless you are running a solid lifter.
Curious why the offset TA rocker is "better" vs the 273 setup? I understand if going that era of 340, but I'm planning on a 340 with adjustable solid drivetrain.
Thanks.
Found some more....
I was thinking the 3/8 Hex heads were OEMs but from the above pic it looks like they were slotted .
You guys got it figured out yet? 24 posts and Steve still doesn't have any adjusters!
