Of course only one comment of someone who actually uses them...not hundred of comments of people who never used them but call them junk..cause they sister brother uncle said so....LOL
Yeah, you have to read everything and judge the validity, and see if you can find any other info on WHY problems were experienced.... high lift for example; or the poster is a clueless fool in general LOL. You're good to say what and how much you have used them; any valve lift info you can share in this applicatio?
For our 'take your chances' foray on rockers..... We recently got a set of what look to be PRW's on eBay for about $225. The have the PRW 'PQ' markings on the rockers, and when we looked up the 'ship from' address, it was for PRW in CA. The box says PRW, and the seller confirmed that they are older surplus PRW's. I'll venture to guess that these are complete sets put together from broken sets or possibly returns, as the markings on the rockers have different type styles. This seller offers both 1.5 and 1.6 ratios. (Or maybe this seller is really good at faking in markings and ship to addresses!)
The shaft rollers seem a bit stiff out of the box, so I'll be cleaning/working on them before installation to make sure they roll well. The rest of the parts look like standard PRW stuff, but the hold-downs may be the older style. The castings look smooth on the edges with just 1 or 2 nicks or imperfections that we will smooth off to try to avoid a stress riser.
Can't give you any usage reports yet; we'll be trying them but will be checking the shafts and everything carefully at frequent intervals for a while to see if those are wearing adversely on the street. I can't say if they are good, bad, or indifferent at this time.... we just read a lot on the potential failure points, asked the seller a few simple questions, and took a chance to get something for less. Like so many things, 'you pay your money and take your chances'! Our lift will be at .500" +/-, we aren't using a fast ramp cam that should limit stress on the valvetrain even with the slightly higher ratio, and spring pressures will be typical for that level of lift (< 300# open), so we should not be stressing things too much anywhere. But, we are on our own on trying this one.
http://www.ebay.com/itm/PRW-Mopar-D...90b9dbe&pid=100011&rk=1&rkt=7&sd=161750322893
