Eric_S68
Kev, Let me know when you have the cooler full of beer. I'll come lend a hand. I never did get to look under the Duster! :drinkers:
H22A4 said:Wow, you're going all the way back to the frame rails.... taking it one or two steps more then me. Keep posting the pics!
Eric_S68 said:Lookin Good ! A suggestion though.... Weld in some supports instead of using the wood blocks, With that much cut away, the car is bound to "shift" :thumbup:
Guitar Jones said:We used a piece of tubing tacked to the very rear of the rear frame rails and a plate on the bottom on the floor just to keep things from sagging and the rear window from blowing out.
Otherwise it looks good.
AdamR said:Looks good Kev. Wish I though of this before you started cutting but you should have moved the rear back 1" to gain some tire clearance at the front of the quarter panel.
Any idea what tire / rims your going to run ? I cant decide myself.
Guitar Jones said:I'd suggest just cutting the rocker and stretching the wheel well for a taller tire.
