prodart340
pros,cons, do I have to bore the block out so far that it's beyond street stability? tips? thanks in advance,mike
Get the "Big Inch Mopar Small Blocks" book. They usually carry it at B&N or here on Amazon.
Should tell you what you need to know, very good book and current unlike most of the Mopar-specific books available.
The book the guys mentioned is a good one and explains in laymans terms about strokers.
ProDart to answer one of your questions. No you don't bore the block way out. In fact you don't even have to bore it at all if you don't want to. That's why their called strokers. You change the stroke length (crankshaft) to gain the extra cubic inches.
Pro's: lots of torque and more streetable than a radically cammed 340 or 360. That huge grin you'll get when dropping the hammer.:-D:-D
Con's: not alot except you really should run forged pistons cause the piston speed on a stroker is much more than on a 318/340 or 360. Depending on which rods you use you may have to notch the block for clearance. May also use more fuel cause your right foot will like to live on the floorboard. Can I get an amen 340Sfastback!!:cheers:
What every you do don't buy a kit that is balanced. By the kit unbalanced and get a good reputable local shop to balance it correctly.
flexplate/balancer has nothing to do with 340Fastbacks comment. .
Exactly what Bill said... The balance job done buy the companies is marginal at best. Have a shop do the balance with everything matched up, not pulling weights off boxes... like at least one company does.
flexplate/balancer has nothing to do with 340Fastbacks comment. It's about sloppy work by the distributors. Many of the kits are internally balanced anyways.
No? If have thought it had everything to do with it?
Theres two ways to balance a crank -
1/ Internally through the use of Mallory metal slugs , or
2/ Use an external balance set up like a 360.
Or IF you are talking about "assembly balancing" (matching and weighted pistons) - then we're talking different processes..and I'm all ears.......
Slap an external balance B&M plate on an engine intended to be internal balanced and see what you get.
You can buy kits that are set up for internal or external balance in most cases. The final balance should be done by a reputable shop.
