pharmboy
Skip clifford's blueprinted head. Talk to BJR Racing on here. I'm sure they'll be able to save you about $500 over what clifford's price is. And they'll probably do it in a timely manner.
Honestly, only because I've had five people tell me if I'm getting a carb, it should have an electric choke. You're the first person to suggest otherwise. I really wouldn't know the difference. I'm still pretty green with "real" engines.
I got my Clifford intake at Carlisle for $125 new, never installed, and my headers for $75 used, carb was a gift from my brother in law.
Chuck, check here for valves;
http://cgi.ebay.com/ebaymotors/225-...m14QQhashZitem120298880604QQitemZ120298880604
Glad to see someone willing to go the four barrel route. The only other consideration I had was a Super 6 manifold with a Weber DGV carb. I liked the idea of not having to be running both barrels all of the time.
So what did I do? I checked out the Holley 4150, 390 cfm. By itself, it wasn't enough to get me to commit. Then I found this. Had to have it. OK, I spent a bit more for it than I would have paid for an Offy or Weiand. But this was too cool for me.
fstfish66 said:what is that wild looking intake ?? and i thought the slant 4 bbl intakes were easily gotn new??
That's not bad at all! Yeah, I'm not gonna try that until the new steering box and sway bars go in. I'm running on a stock 7.25, so I'm not going to expect any miracles until after I change out the gears and put in a good stall converter.
Goal 1: Make it road-worth, add A/C and sway bars.
Goal 2: Interior and body work.
Goal 3: More Vroom! (Although I will admit I jumped the gun a bit with the intake.)
don't waste your time changing gears in the 7.25, its still going to break on you. if you hook up at all on a launch its a goner. go ahead and spend the money to put an 8.75 under it and forget about it. -Tim
