Currently I've been running NGK spark plugs with a heat rating of 10 (11 being the coldest plug they make) I took a look at the plugs and from the looks of it they are too cold a plug, a bit sooty and black, no oil though. My motor is a 360 with aluminum heads and 10.6:1 compression ratio, making about 375-400hp. It's a street engine running 94 octane fuel. I think the stock heat rating is about a 4, but because mine has been modified would a 7 or 8 be a better choice?
I need new ones even if you guys think it's a good heat rating, well one at least, I don't know what I did but somehow the white part of the plug that is on the outside of the head by the plug wire got cracked, so I want to replace it before I run it again.
