If it was mine I would rivet it on with steel rivets. Make sure the rivet diameter fits the hole snug.
Factory used some sort of epoxy, I would replicate that and rivet it through the alignment h
Early 1966 and prior Chrysler Products were "Tack" welded in place. 1966 was the first year for Rosette VIN rivets.If it was mine I would rivet it on with steel rivets. Make sure the rivet diameter fits the hole snug
Yes my 66 is spot welded, had a brain fart and thought glued.Early 1966 and prior Chrysler Products were "Tack" welded in place. 1966 was the first year for Rosette VIN rivets.
Awesome stuff just allow to Fully cure !!!!I noticed one end of Vixen's serial number tag has come unstuck from the door jamb. What's a good adhesive to use that will hold it back in place? Would something like liquid nails work for that?
It is spot welded. See post 18.My 63 has some kind of adhesive holding the VIN plate to the door jamb
