Piston_Freddy
I bought a '68 Charger with a Hurst promatic 2 shifter installed.Problem is that I have to move the shifter twice to get it into 2nd gear and I have to pull it up to get it in to neutral.
Stock mopar,chebby,phord and mopar level.It has the welded one on.Is that the correct level that comes with the kit?
In witch gear the level hole and cable thingy have to be at the same spot? I tried once to adjust it with no success.Any ideas? Thanks!
