Would just be my dusters and 67 coronet on a 4postMy neighbor does the top of the lift is above the ceiling rafters. . OK for small cars but anything with a tall roof your using an Office chair under the car
This one will be 10’ at the back end and about 13’ at the front end. I’ll probably be installing an Atlas BP8000 lift which only requires a 9’3” ceiling to get the posts set up.Does anyone have 10ft walls/ceiling height with a lift in it to see how tight it is.or if.even possible?
I'm not a good one to ask. My shop is 24 x 28 and I hate it. I have stuff everywhere with no real rhyme or reason. I'm just not a good organizer. I wish I was.
No matter how many square feet, you'll never have enough room.
Oh absolutely. I am blessed far more than I deserve. Didn't mean to sound like I was complaining. Far from it. I just SUCK at organizing. lolAt least you have a shop.
Pack it full of your goodies, you will find things when you need them.
Does the car on the lift go higher then the posts????.. You may have to buy a Lambo to park under the one on top. Measure the height of both cars to be stored and add the thickness of the lift cross beams.This one will be 10’ at the back end and about 13’ at the front end. I’ll probably be installing an Atlas BP8000 lift which only requires a 9’3” ceiling to get the posts set up.
Yeah it does. But I just looked up the specs on it and it lifts up to 6’2” with all the adapters. I’m 6’4” so once the concrete is poured and the rafters are up, I’ll have to measure and see if I can’t get the 9000 model instead. That one lifts up to 6’8”Does the car on the lift go higher then the posts????.. You may have to buy a Lambo to park under the one on top. Measure the height of both cars to be stored and add the thickness of the lift cross beams.
Keep in mind the bottom of the vehicle will be much higher than that 6'-2".Yeah it does. But I just looked up the specs on it and it lifts up to 6’2” with all the adapters. I’m 6’4” so once the concrete is poured and the rafters are up, I’ll have to measure and see if I can’t get the 9000 model instead. That one lifts up to 6’8”
