Show off your small block.
Teener before-
after
before
after
All,
Here she is All complete! A little more wiring appearance cleanup to be done.
367 cubes of Fuel Injected Fury!
FiTech Injection, Indy/RHS X heads, Comp XE 274 bumpstick, 10.2-1 w/ Speed Pro Coated 116CP flattop slugs, GM HEI, Hooker Super Comps, Eddie Air Gap Manifold.
Not perfect but pretty clean and runs out great! Have about 300 miles on it.
Thanks,
Marion
Hey fasttcars can you share what color is your car? That color is very nice!! Also mind sharing cam and other specs of that beautiful machine, please?:steering::thumbsup:
It's not in the car. heh
'74 318 block if memory serves.
Offenhauser 5488 for early 273, need to either get some angled shims or mill the intake bolt flange angle.
302 heads with 1.78" 1.50" valves. will go on the 318 that is currently in the car, not on this build. Just mating everything up to check the intake manifold bolt angles.
Mallory 4757901H dizzy on shelf out of picture
ductile iron 1.5 rockers
Doug's D452 headers on shelf
timing chain cover
Just collecting parts and stacking them up.
still need;
water pump
gaskets
rotating ***'y
bearings and freezeplugs
oil pump
solid flat tappet cam
rocker shafts
milodon timing gear
harmonic damper
oil pan
windage tray
oil pump shaft
carbs
nuts, bolts, studs
orange paint
