Show off your small block.
1974 Sport with 408 stroker.
What's that pcv tank thing you got going on there @DesertRat?
If you are looking at the one next to the radiator it is my overflow catch unit. It feeds from the bottom and overflows from the top. Hasn't been occasion to use it as my motor runs between 185 and 200 rock steady with a 7# cap. There is the windshield washer fluid container which is white. On the right inner fender is my Wagner adjustable PCV and Moroso oil separator.
The aluminum can by the blower motor. It looks like the pcv is hooked to it.
That is sure looking business, but please get rid of them red hoses... :icon_fU:
Long gone...If I had the 2X4 top, Id still have it but I bought the base only. Only way I could have afforded it.
thanx for the positive reviews, I always liked the 64 Thunderbolts so this is my A Body take on it.
I moved the battery to the trunk and grafted in the 4" tubes to the rad support. Inlets are behind the park lights out of sight. Had to drop the alt and the A/C pump to make room for the tubes. A Spectre air box 16"x 4" sits on a FITech 600, on top of a Edelbrock Air Gap. I had to drop the dropped base another 3/4" but now there is 3/8 clearance to the hood. Not sure why guys are having trouble with clearance with Air Gaps, maybe difference between Dart and Formula S hoods. I think the trick is to be wider (16") to have room to drop it without hitting the linkage. The FiTech will read out inlet air temp so it'll be interesting how much cooler it'll be with the tubes connected and disconnected. Need some hot weather to check that out. Larry
Got the cam broken in a few days ago, timing dialed in yesterday and she's running like a beast!
