Show your 5x4 small bolt pattern wheels!
14x7 Ralleys on the Rear.
I love the turbo thrust wheels,,, are they 4 inch bolt pattern?
Looks like many liked the spoked wheels
I don't know if this has been addressed in this thread, but....
The only place I know that still does torque thrust style wheels in 5 on 4, is ET mags/Team III Wheels. Available in various sizes and backspaces... but NOT cheap (starting at about $500/wheel). All in all, not TOO bad for a custom wheel.
Boyd Coddington used to make a 17x7 and 17x8 version in small pattern, at about half that price, but I don't know if they are still available.
I will eventually install BP axles and Dr Diff front and rear discs with aluminum master cylinder and proportioning valve
The 14 tire selection is too limited
As well as the quality of compound you want.
Former setup: 15x7 Centerlines, 255/60/15s on back, 225/60/15s front
Edit: Oops, just remembered this setup the fronts were 14x6 wheels with 225/60/14 tires.
Replaced by Cragar SS, 15x8 rear, 15x7 front, 275/60/15 Nittos in rear, 225/60/15 Falkens front
Another edit: first picture below had Goodrich 235/60/15 drag radials on the rear. Wore them out and replaced them with the 275/60 Nittos shown in the bottom pic. They are 28 inches tall vs. the 26 inch tall Goodriches.
OMG! THAT! is The Coolest Car I have Ever Seen!
So, Jealous! Searched for a 4-Speed 2nd Gen since 1994... settled on a 1st Gen after 30 years of looking.
245/60/15 rear and 205/60/15 fronts.
Currently looking for another rwl in similar size to 205.
Good luck with that! I can't find anything with RWL 15s smaller than 235 60 15.
Coker MIGHT have something, but ill bet the price will be crazy, and the quality suspect.
You could try Diamondback, or maybe get blackwalls in the size you need, and add lettters.
