68cuda05gto
Thank you! I plan to get this done and pray nothing destroys this one!You are persistent, stay that way..
I have done diablo tuners but it was only for one vehicle. I deal with EFIlive and HP tuners the most. I will need to get into diablo for the 6.4 or 6.1 hemi engine.So you can program a Diablo? My engine is in pieces and is on its way to a 420 have a 247/255 cam coming as well.
Awesome man I will have to check out your build.My car went off to the body shop on the same day... also a '68 Notch...
http://www.forabodiesonly.com/mopar/showpost.php?p=1970149795&postcount=126
I am using rust bullet (similar to por 15). But since you had the car blasted, you do not really need a rust encapsulation product. A healthy dose of quality seam sealer and paint should be just fine.
I too am avoiding using undercoating on the bottom of the floorpan, and instead using strategically placed dynamat on the interior of the floor to provide vibration dampening.
Ok that sound like a great plan. What seam sealer did you use? I see tons of brands. BTW I want to copy your firewall if you don't mind?rayer:
