MOPAROFFICIAL
Oogliboogli
I posted a long time ago that article of the slant head that had all its I take runners bored at a steeper angle and tubes pressed and brazed into the bowl area.
Cricket Wagon, "Deep Six" I wonder where that head is ….Cars magazine 1974
Pacer or colt iirr.
.. that's the / head I want.
And remember, if the slant head is completely redesigned to be a cross flow, you will also need to design and manufacture new intake and exhaust manifolds as what is on market today would not bolt up. So that is another slug of $ on top of the slug of $ for the new head.Unless it's COMPLETELY redesigned, as in a cross flow, OR SOMEHOW move the valves around for better port configuration, I don't think there's a lot of room for improvement, other than simply being made out of lighter aluminum. The ports are already the limiting factor, and unless they are "moved around" for optimum placement, there's not much to gain, IMO. Problem is, there ain't a lot of room "THERE". This dream pops up about every couple of years, so we're used to it.
Why go to a cross flow head if you plan to stay with the existing port locations and sizing?Exactly. I wonder though.......if it would be possible to design a cross flow head and use the stock manifolds? It's not like the HAVE to be mated to each other, OR on the same side. ......regardless, either manifold would be a TIGHT or impossible fit on the passenger's side. I don't believe it could be done.
'cuz I'm retard.
I mean retired.
Yep, that from the thread?Cricket Wagon, "Deep Six" I wonder where that head is ….
LOL!!!!!
I have really great, viable ideas for an Al-u-minimum head that can accommodate the gamut of apps. Unfortunately I've been extremely short on time the last couple of yrs., just diagrams, sketches, & some scale drawrings........sigh..........+1. This is what happens when the subject of an aluminum cylinder head for the \6 comes up.
Each.
And.
Every.
Single.
Time.
Without.
Fail.
Does anyone have any pictures of this head in a finished state?Cricket Wagon, "Deep Six" I wonder where that head is ….
GD, that's a big hunk of AL.A shop nearby builds heads for tractor pullers. This is a John Deere head. A alcohol burner I believe. They don't need cooling passages that way.
I don't doubt you. You're not the only one—there have been great, viable ideas turned into great, buildable drawings and plans. What nobody has (or is likely ever to have) is the money and time and inclination and resources and facilities to turn any such drawings and plans into aluminum heads, let alone at a price anyone's actually going to pay.
