Preach it brother. lolWhere is that big stick. Need to beat on this dead horse.
Dare I say it......are those Ron's Flying Toilets? Sure looks like um. Are there any details on the head anywhere? Like the weight difference alone would be worth it, but I'm curious about port placement, valve sizes, flow and so on. And on. And on. LOLOK, here it is. One of one aluminum slant six head. It is real and runs.
Scroll to bottom of page for more pics
Billet Aluminum Slant 6 Head! Seriously!! - Page 9 - Slant Six Forum
video
(13) Slant 6 Dart - YouTube
Pretty cool historical artifact, great to see it's still kickin' around, wonder if the plan is to preserve or actually put into service on some level?That OHC engine resurfaced a few years ago. There is a thread on slantsix.org about it. I believe it was sold on ebay.
It was. I remember seeing the ad.That OHC engine resurfaced a few years ago. There is a thread on slantsix.org about it. I believe it was sold on ebay.
Good for a quarter mile at a time and running on alcohol. Hey I can get you one of those.OK, here it is. One of one aluminum slant six head. It is real and runs.
video
Back around 1979, Larry Sheppard referred me to someone at Chrysler (can't remember his name) about the turbo program. At the time I was contemplating installing a turbo on my 65 Valiant 170 slant six. Back then, there wasn't much info available about turbo conversions, and I was looking for some basic info. My contact at Chrysler, told me, they had cancelled the program, as they couldn't make the engine live. They would not give me any info at all. Not god, bad, or indifferent. I was told that Chrys was looking at the turbo system for trucks.
It amazes Me that Chrysler bothered to do the heads like Rusty's & the one above with no apparent clue as to how to take advantage of them.Back around 1979, Larry Sheppard referred me to someone at Chrysler (can't remember his name) about the turbo program. At the time I was contemplating installing a turbo on my 65 Valiant 170 slant six. Back then, there wasn't much info available about turbo conversions, and I was looking for some basic info. My contact at Chrysler, told me, they had cancelled the program, as they couldn't make the engine live. They would not give me any info at all. Not god, bad, or indifferent. I was told that Chrys was looking at the turbo system for trucks.
I wound up doing it anyway. The biggest problem I had was with the "tune up". Having no/low boost drivability, without detonation at boost. Back them there was no such time as AFR gauges, or "boost timing masters". By 1981 I was driving the car to the track, and running 13.4's at 104 mph. about 11-12 lbs boost. The only engine failures I had were caused by detonation (head gasket, rings, pistons). I used a Rajay F70 turbo
In the early days (late 70's to mid 80's) Most OEM turbos were draw through. It wasn't untill the advent of FI and computer control, that draw thru went away.As a draw-thru' carb setup, a la early Buick Riviera & T-type, it seems it was doomed at inception.
Yes pretty much all of them, 301 Ponchos, just had one in the shop about 3yrs. back. Indy Pace Car edition TA, still ran. The old 2.3 turbo Mustangs, same era, Colts.......We had an '83 T-Riviera, ended up changing the turbo, ran fine. Smokey Yunick's "Hot Air Engine" used a draw-thru "Homogenizer", but required synthetic oil to live.In the early days (late 70's to mid 80's) Most OEM turbos were draw through. It wasn't untill the advent of FI and computer control, that draw thru went away.
I have a Corvair turbo on the shelf, and also a "complete" 301 poncho setup including the correct carb. Also have a NOS Rajay 301E80 turboYes pretty much all of them, 301 Ponchos, just had one in the shop about 3yrs. back. Indy Pace Car edition TA, still ran. The old 2.3 turbo Mustangs, same era, Colts.......We had an '83 T-Riviera, ended up changing the turbo, ran fine. Smokey Yunick's "Hot Air Engine" used a draw-thru "Homogenizer", but required synthetic oil to live.
Plus, those bathtub chambers just shrouded the hell out of the valves. Talk about reduced flow.It amazes Me that Chrysler bothered to do the heads like Rusty's & the one above with no apparent clue as to how to take advantage of them.
The bathtub head probably destroyed chamber swirl almost completely, & without a piston near-deck to generate squish, They killed what detonation resistance there was then boosted it!!!! As a draw-thru' carb setup, a la early Buick Riviera & T-type, it seems it was doomed at inception.
The Pontiac 301 setup I always thought would be good for a slant 6.I have a Corvair turbo on the shelf, and also a "complete" 301 poncho setup including the correct carb. Also have a NOS Rajay 301E80 turbo
Wow Man, sounds like you had alot going on back then! No Support, Learning Curve, ect! You seem like an innovative Mopar Man!Back around 1979, Larry Sheppard referred me to someone at Chrysler (can't remember his name) about the turbo program. At the time I was contemplating installing a turbo on my 65 Valiant 170 slant six. Back then, there wasn't much info available about turbo conversions, and I was looking for some basic info. My contact at Chrysler, told me, they had cancelled the program, as they couldn't make the engine live. They would not give me any info at all. Not god, bad, or indifferent. I was told that Chrys was looking at the turbo system for trucks.
You should see his scrap books. It's amazing the amount of experience Charlie has.Wow Man, sounds like you had alot going on back then! No Support, Learning Curve, ect! You seem like an innovative Mopar Man!
I'd love to! It sounded like he Made the Experience, just from reading what Lil I did. Obviously, he is not tooting his own horn, and I don't really know his background, but he seemed like an OG at that! Just wild Man!You should see his scrap books. It's amazing the amount of experience Charlie has.
