You couldda already have picked up some chicks by now with a carburetor.
To pick up a chicken, follow these steps:You couldda already have picked up some chicks by now with a carburetor.
Remember, practice makes perfect! Handling chickens becomes easier with experience.
- Approach Calmly: Chickens can be skittish, so approach them slowly and calmly. Avoid sudden movements or loud noises.
- Secure the Wings: Gently place one hand over the chicken’s back, securing its wings against its body. This prevents flapping and helps you maintain control.
- Lift with Both Hands: Use your other hand to scoop up the chicken from underneath. Lift it by supporting its body with both hands. Keep the chicken close to your chest to prevent it from struggling.
- Hold Firmly but Gently: Chickens are delicate, so avoid squeezing too tightly. Hold them firmly enough to prevent escape but gently enough to avoid causing harm.
- Keep Calm: If the chicken squirms or flaps, stay calm. Talk soothingly to reassure it. Once you have a good grip, you can carry it to its destination.
Last time I caught them with a hand held fishing net. Then took them to the hatchet............To pick up a chicken, follow these steps:
You think there’s any less tuning involved with a blow through supercharged carbureted application? There might be less setup, but the amount of work involved is similar.You couldda already have picked up some chicks by now with a carburetor.
For me, yes.You think there’s any less tuning involved with a blow through supercharged carbureted application? There might be less setup, but the amount of work involved is similar.
Are you being theoretical? Or have you actually set up and tuned a blow through supercharged carbureted set up? If so what was it?For me, yes.
Blow through. No. Not yet. I have built and tuned a few roots blown engines. I plan to again.Are you being theoretical? Or have you actually set up and tuned a blow through supercharged carbureted set up? If so what was it?
Gotcha. So you were being theoretical. I don’t doubt your carb tuning ability but until you’ve pulled your hair out one by one trying to dial in a blow through carb (turbo or supercharged) you won’t understand why I questioned your statement.Blow through. No. Not yet. I have built and tuned a few roots blown engines. I plan to again.
I'm sure you're right. The trick to carburetor tuning is one thing and one thing only. Don't give up. Sometimes it just takes some time.Gotcha. So you were being theoretical. I don’t doubt your carb tuning ability but until you’ve pulled your hair out one by one trying to dial in a blow through carb (turbo or supercharged) you won’t understand why I questioned your statement.
That does look a LOT cleaner than 99% of turbo or blower installs I've ever seen. That's nice.Good news. Cut all the unused wires out of the factory harness, rewrapped it, reinstalled, and the car still managed to start when done. I must not have accidentally cut out anything important!
I'm pretty happy with how the install is turning out to look. I'm excited to get to drive it again soon.
On the supercharger kit do they offer different crank pulleys? Mix and match pulley sizes can be fun (NOT) but you can dial in the shaft speed and PSI. Sometimes a 1/2 inch change on just the top pulley can be too much.
And you want as large of pulleys, matched of course, so the belt has better grip. Might not matter on a \6.
Make sure there is a baffle inside the valve cover, below the PCV valve, to keep direct oil splash off that valve/gromet.I got the modification needed done at the exhaust shop today, so thankfully the column shift linkage isn't dragging against the exhaust anymore. Made it much easier to do some shifting on my own tonight.
I'm up to almost 100 miles on it so far since starting on Sunday. Running really well - really haven't played with timing or anything yet but will get into that soon.
For reference, ran it up to about 5000 rpm tonight and boost was about 7 psi there. Nothing exploded that I could see, so I guess that's a good sign.
I do see I'm getting a little oil collecting on top of the valve cover around the PCV Valve. Perhaps there is something special I need to do there- time for more research.
Blow-By is always an issue on pressure fed engines. Ring control goes all wonky with pressure and HEAT.
Someone asked early in this post if you had opened up the top piston ring end gap.
