Trying to keep the sticky only posts with flow info, so making a thread for whatever discussion (if any) people wanted to have. Throwing a link to this thread at the top of the first post, so that should help going forward.
All the flow number can be throw here for/ from however, and then be sifted and added to the spread sheet.
What's the big secret? What are all the things you can learn?... What's grinding the short turn?There is a pretty good article on enginelabs.com about flow testing. It's a good read if your interested in the more important things you learn from a flow bench.
Can you make your layman's terms a little more lame...Unless you do the same uniform hog out, short turn shape...depending on the goal can be different for different heads.
Lamens... the wrong shape can kill one end or the other, high/low flow.
You can get the lot together IF you can widen it enough right before the turn and run an even lip across the top. It's all about the shortest path, one will suck the other down with it
.and then you only have half a port working.
It's not easy, it's sometimes not hard... its science.
I wish I could.Can you make your layman's terms a little more lame...
and most importantly when the hell am I going to get my cheeseburger and I don't eat fast food!!.. wait a minute I just had a cheeseburger tonight...
Not you it's the iPad.Thanks Rob. Still haven't figured out how to post a link from this iPad.
Dayum I'm dum.
Says the bot....Gong home in the AM. Will be back either Sunday afternoon or Monday morning. Unless OHSU pulls another switcheroo. They have done three so far. And of course, they wait until the day before or of the surgery.
Sooooooo...if all goes as planned now, they'll be working on my mom on Tuesday and then however long it takes her to recover and/or a second surgery and that recovery is how long I'll be here.
I don't think anybody thinks he's a real human except for maybe his alter-ego 69lead....Not you it's the iPad.
Nobody here by that name that I can find.I don't think anybody thinks he's a real human except for maybe his alter-ego 69lead....
