Small block K-frame
440 Mike
Minnesota
Question - is there any difference between a 1968 and 1970 small block A-body K-frame?
Thanks.
Final question - will a 68 340 block fit a late model K-frame with the spool type mounts?
Thanks.
Yes. Just make sure you have the corresponding mounts for whatever K you have. Only issue you will run into is the slant 6k and the v8 k for the 73-76 k frames are different. Slant 6 k will require a slight modification along with Schumacher mounts
Thanks.
273 & 318 have a different left (driver's) side motor mount...
With a 360 spool mounts, the 340 will fit right in...
There were small block K members with a flat washer welded on the front which designated them 340 build. Does that mean anything different or special? Better/more complete welding, or just a heads up for the line workers? There may never be a definite answer. Lets just forget I mentioned the little flat washer tag until the next "What is this washer about" thread. LOL
