no.Question - is there any difference between a 1968 and 1970 small block A-body K-frame?
Remember that the 67 has a different idler arm bracket and requires 67 only idler arm unless bracket is modified.67 thru 72 are the same.
Yes. Just make sure you have the corresponding mounts for whatever K you have. Only issue you will run into is the slant 6k and the v8 k for the 73-76 k frames are different. Slant 6 k will require a slight modification along with Schumacher mountsThanks.
Final question - will a 68 340 block fit a late model K-frame with the spool type mounts?
Thanks.
