Friend 1- 408, Shady Dell stage 2 RPMs, cast crank, stock block, custom medium size solid roller (
[email protected]), MP M1 single plane, 950 BIGs Holley, full exhaust, 3500lbsw/driver street car: In '72ish Duster, 727, 4.10s, 28x10 slicks, 100hp NOS shot 10.48, of the bottle 11.20s in 100+ Vegas heat.
Friend 2 - 426 (340+060/4"), my "stage 2" ported "587s", Crane H302-2 hydraulic cam, RPM AG, Street Avenger 870VS, with 727, 3.23s in 3700lbs Challenger 12.0s at 109+ with wheel spin (1.88 60'...lol)
Friend 3 - 408, cleaned up RPMs, hydraulic cam apprx
[email protected], RPM AG intake, Holley 850DP, with 727, 3.91s in a factory stock loaded Mirada (4200lbs + w/330lbs driver), 12.20s at 110.
Friend 4 - 416, Shady Dell CNC RPMs, medium sized (
[email protected]) solid roller, with 6bbl intake and carbs, not run at track, but makes 450hp to the tires on the chassis dyno. 480 with an AG and 950 Holley on it on the same day.
Sounds like you've got some left to find, but you're doing fine.
These are all pump gas primarily street cars.
