you and everyone else. lol to think that cheesy snap ring keeping the axle from sliding out. lmaowell...I always remove the 5 nuts and slide the axle out along with the back plate.....
.well...I always remove the 5 nuts and slide the axle out along with the back plate.....
I see you checked the dana axle and now see our lives are depending on a wire clip holding the axle in place.
Missed the film at 11.
Yes you have to take the retainer plate loose to get the axle out. That was not my point. The clip keeps the axle from sliding out is my point.
.No, the snap ring keeps the axle, and ALL from sliding out. lol
Explain ALL please.
If rhe clip is missing or fails the axle along with the bearing assemble can slide out.
If you remove the 5 nuts you pull the axle assemble out but the backing plates do not come off because the brake lines are still attached to them.
The wiring was never good in the first place LOL I've already changed that. The master cylinders are only 20 bucks get a grip LOL someone bypass the neutral safety switch. Get that fixed and it won't start in gear.Thanks everyone
Yes i removed the 5 bolts that hold on the backing plate
Tomorrow I will try the drum slide trick
I'm starting to hate this car and regret buying it
everything and i mean everything is fucked
wiring was shot
Master cylinder fried by fender wall headers and leaked inside
car will start in any gear
carb was shot
and so on
Good luck, I hope I wasn't too hard on ya LOLGot the axle out tonight it was rusted in pretty good
Now to test the green bearing and replace it and rebuild the rear end
Wish me luck guys
Cool, and when I change the ring and pinion in mine I'm I'm going to share that as well. I've rebuild my transmission, and every other thing on the car and still have not set the Lash in my own rear end. That little piece of knowledge is going to be learned.Thanks J par
the snap ring was nothing more than retainer on the green bearing
When the rear end is done I will rewire the car and start a thread for that for everyone else to follow
