Well, if you don't allready have adjustable rockers.... custom length pushrods may be in order. Check the length you need and maybe an off the shelf set of pushrods will do ya good.
It's often said, Periodic adjustments need to be made" AKA readjusting lash. Well, it may be true, but it's not weekend chore. Honestly, if ya did it once a year, I'd call that ALOT!
The solid cam has a few more RPM's to it over a Hyd cam. Not really so much that it makes more power than a Hyd because it is a solid, but so designed to make more power than it's equal as a Hyd. would.
The cam also has the abilty to have ground into it, a quicker steeper ramp for quickly raising the valve. This translates into more power. But just because it can be ground in doesn't automaticly mean it is done.
