JimmyV
MOPAR!!
Hey Just Want A Little Bit Of A Freshend Memory On Solid Lifter Valve Adjustment On A 360 290 Duration 525 Lift Solid Cam I Know The Order But Whats A Good Clearance
usually with aluminum heads on a cast iron block...subtract .006 from lash...
its on the cam card
Not sure how the valvetrain geometry compares to a "V" configuration, but I'd think adding 0.002" should get it close.what about all cast iron slant?
it takes you that long to do your adjustments? warm the car to 180 then start adjusting... Shouldent take more than 10-15mins
