Solod motor mounts
Small Block Mopar Engine
  1. B3422w5
    B3422w5 Well-Known Member
    1,576
    1639
    Feb 9, 2017
    Portage michigan
    Local Time:
    2:29 AM
    Anyone running just the solid mounts on both sides
  2. Alaskan_TA
    Alaskan_TA Well-Known Member
    5,930
    4329
    Nov 12, 2004
    PA
    Local Time:
    2:29 AM
    I run solid on the drivers side only, that way the passenger side has some cushion.
    No vibrations in my cars.
  3. B3422w5
    1,576
    1639
    Feb 9, 2017
    Portage michigan
    Local Time:
    2:29 AM
    i don't care about vibration. Its a 12.5 to 1 stroker with bullets on it....lol
    Just checking to make sure no issues other than dealing with vibration
  4. crackedback
    crackedback FABO Gold Member FABO Gold Member
    18,895
    3327
    Aug 7, 2005
    92201
    Local Time:
    11:29 PM
    no issues.
    run a flexible trans mount, no solid there
    • Agree Agree x 3
    • Like Like x 1
    • Thanks! Thanks! x 1
    • yellow rose
      yellow rose Overnight Sensation FABO Gold Member
      28,102
      24391
      Jun 19, 2015
      Central Washington
      Local Time:
      11:29 PM
      ^^^^^^^^^^THIS^^^^^ I use solid on both sides on the street.
    • B3422w5
      1,576
      1639
      Feb 9, 2017
      Portage michigan
      Local Time:
      2:29 AM
      Thanks for the advice guys!
    • famous bob
      famous bob mopar misfit
      19,530
      8592
      Aug 14, 2011
      okla
      Local Time:
      1:29 AM
      SHOULDN`T BE ANY DIFF. FROM RUNNING A MOTOR PLATE , W/ EXCEPTION OF FORE AND AFT MOVEMENT -------jmo
      Altho I think I `ve read of the ears breaking off of the block-
    • dartindanno
      dartindanno Well-Known Member
      437
      600
      Aug 25, 2011
      Kenosha, WI
      Local Time:
      1:29 AM
      I switched to solid mounts after breaking 2 sets of stock mounts and the drivers side of the poly-loc mounts. No racing yet but the vibration on the street isn't much more than the poly-loc mounts
      • Like Like x 1
      • Agree Agree x 1
      • flyfish
        flyfish C8H18+N2O = :-D
        2,284
        868
        Apr 16, 2007
        Indy
        Local Time:
        2:29 AM
        I run solid mounts on my engine, with a poly transmission mount....I've been running it like this since the early 2000's. The only down side is you will have a few bolts try to wiggle loose every now and then. I just make it part of my yearly racing season prep to check header bolts, starter bolts (those are the only ones on my car that vibrate loose).
        • Agree Agree x 1
        • B3422w5
          1,576
          1639
          Feb 9, 2017
          Portage michigan
          Local Time:
          2:29 AM
          what you are doing is exactly the setup i plan to have.
          Will keep an eye on stuff trying to loosen up
          • Like Like x 2
