fishy68
Tyr Fryr's Inc.
the funniest thing is I asked them to price match eBay and they found it cheaper than I did! Who was I to argue?
Cool! Can't beat that
I noticed the instructions said it will read lean at idle with a lot of overlap ? I have around 260 @.50 overlap and around 535 lift. Right now as i read through the instructions for tomorrow , i noticed I can't hook the power up to anything basically that runs anything else ? One long wire (another one !) Through the firewall to the battery in the back ?Several things affect what you'll need to run it at but the biggest thing I've noticed is if you have a big lumpy cam you'll have to run it pretty rich to get it to idle decent. I have a fairly mild cam in mine and run the idle as lean as I can to try and get some fuel mileage out of it. Around 13.8~14 to 1 in drive is where I run it. At WOT it runs best right about 12.5 to 1
Thank you all again.....
I'm really looking at a way to use it more for test & tune than a permanent mount ? Use little motorcycle batteryHum... I'd think it'd read rich at idle with a lot of overlap cause you usually have to run it rich with a lot of overlap, but I don't know that unit so I can't say positively. I have mine wired to a main B+ block I installed to power all the peripherals and don't have any problems, but it's not the same unit as you have either. I imagine their worried about noise generated by something else affecting it. Generally a good capacitor like the kind you use with high power stereo's will kill the noise
(No interference) and put sparkplug in bung when not in use. I could weld bung in girlfriends Barracuda and tune it also?
"More power!" ? Yikes ! On the test drive i came around a corner to a long open straight in second and at three grade pushed the loud pedal down about halfway - well it went sideways for a half block as my gal was screaming -YYEEEEE HHAAAAAAA!!!! Until I get a little more use to this stroker motor I'll probably only notice more power on my time slip at the track. I'm sure you're correct . I think my first step is to identify the metering rods & jets to know how to proceed ?You may already know this but 11.7 to 11.8 is pretty rich if it's straight gasoline (no ethanol). You'll probably make more power if you lean it out some. Plus it won't load up the plugs so bad
