Lucky You, You don't live in the 5-county Philly area, with the dyno/sniffing....What the heck is a freaking tailpipe test. Lol
well, it all starts when a man and a woman love each other very much...What the heck is a freaking tailpipe test. Lol
Yeah, I knew a few who did that, I got My IM license '85....always did My own. Funny one, before I put the PurpleShaft 284°/.484" in the '66 383, it sniffed clean for an '83 318 Diplomat.....passed with flying colors w/a 3310 750 on it, lololol...Back before I bought my house in 1984 I live in Allegheny county which is the same county as pittsburgh. I refused to have mine done for the 5-7 years it’s was required. Back then it wasn’t tied into your state inspection so I rolled the dice and won.
yes, here in the uk cars have to have a tailpipe emissions test every year as part of the 'mot' (roadworthyness/safety) test. the level of acceptable emissions gets lower as the vehicles get newer so pretty standard stuff i guess.Here in Missouri they used to have a hose that went into the tailpipe while the engine was running, this measured all of the emissions going out of the exhaust. It was given the nick name tailpipe sniffer
I'm no expert on this topic, but why could you not sleave a 318 block with 340 sleaves?No need for a 340 block, just use a 318 block.
I suppose you could unless you run into water boring for the sleeves. Some teen blocks are pretty thick. Sconic check to make sure.I'm no expert on this topic, but why could you not sleave a 318 block with 340 sleaves?
Are not the molds still around from the original 340 blocks? My understanding, all the 340 blocks were from the same casting molds. 68'- 73'. Where are they? Finding them would cut the cost down from starting from scratch. Maybe offer the "TA" (4 bolt main) instead of the light weight 340.you hit on something very important here: breaking even isn't the same as making money!
as an exercise say, 3K price point on a 340 block you'd have to sell 100 to break even at your initial 300K investment. and what's the ROI time wise? 18mo? two years? there's better, faster money to be made with that coin. (granted 2nd run with amortized costs and built in process, but still... you clear what? 1500 on a block? so now you have to sell another 100 to bank 50%)
then, you have as @AndyF noted, if you're gonna do it why not go ahead and make it better? well, then you're in the boat of needing proprietary or specialty bits. which, that's cool if you also produce those and are seeing some dough there but a huge bummer for the guy looking to buy a repop 340 block and transfer all his stuff over and not have to drop 1500 at the machine shop and 2K for a cam & lifters.
it's a great idea, but it's 100% about volume and there's just not enough there.
if the angle already existed, MP would've covered it, made it and then backed us into the corner, knife out and demanded our wallets.
which, granted, many would've gladly opened up and let them go elbow deep in the calf skin. but that's the 1% of the 1% of dudes that are all: "i'd totally buy a 340 block if they made 'em".
and that brings us to the age old truism of: cash talks and bullshit walks.
The club I help start in 87' had the same issue with Mother Mopar. We finally did get permission to use the Pentastar in our club Logo. We also new some big shots then. Times sure have changed.Same reason Chrysler wouldn't let us use the Pentastar when we founded The Middle Georgis Mopar Club about 30 years ago. We sent a letter to their legal department asking permission just to cover our butts. They said no. We did it anyway. lol
I googled this to be sure, no factory 340 blocks came with 4 bolt mains. The block did have thicker webbing if you wanted to go to 4 bolt mains. The aftermarket blocks are a 4 bolt main bearing block.Are not the molds still around from the original 340 blocks? My understanding, all the 340 blocks were from the same casting molds. 68'- 73'. Where are they? Finding them would cut the cost down from starting from scratch. Maybe offer the "TA" (4 bolt main) instead of the light weight 340.
I believe it was all about the "long" stroke for a work truck. The slant 6's did well, with its long stroke. I had a 67' Dodge HD w/ the slant 6 and grainy gear and it was a work horse.Not even close to the grunt of a big block, not even the lowly 383. lol
The worst thing Mopar ever did is to put a low compression 360 in a 5000# truck
Are not the molds still around from the original 340 blocks? My understanding, all the 340 blocks were from the same casting molds. 68'- 73'. Where are they? Finding them would cut the cost down from starting from scratch. Maybe offer at the "TA" (4 bolt main) instead of the light weight 340.
My understanding is that the meat was there in the "TA", but needed to be drilled for the extra bolts.I googled this to be sure, no factory 340 blocks came with 4 bolt mains. The block did have thicker webbing if you wanted to go to 4 bolt mains. The aftermarket blocks are a 4 bolt main bearing block.
Why? 4.04 vs 3.91 ID. That is .13 of an inch. Not worth the expense. 340 power was in the combination of heads, cam, compression, ignition curve, exhaust, and induction. It really is that simple. 340 blocks are a little stronger, but they are both made of good material. No one wants a 318, so just swap the good stuff onto any small block and you have a power house.I'm no expert on this topic, but why could you not sleave a 318 block with 340 sleaves?
Agree I had a 1977 Ramcharger with a 360 , it was a dog had 2 360's replaced under warranty , after that put in a 4406 pac block with a torker and 850 holley made a huge difference Truck was a blast with the 440 .I believe it was all about the "long" stroke for a work truck. The slant 6's did well, with its long stroke. I had a 67' Dodge HD w/ the slant 6 and grainy gear and it was a work horse.
We are in the same age frame, I'm 68 and still having fun with my 340's. Sonny and Ronny Sox, Don Garlets and Darrell Gwynne were regulars at our annual show in Hollywood, Florida. Galen Govier showed the first few years and put on a Judging class for our judging staff. I was one of 11 to attend. I learned a lot from it and try to pass on the knowledge to others. I consider all of us in this forum a "TEAM PLAYER" in our hobby. Many of my comments start with, "I believe or if I remember correctly", is because I'm am 68 and 40-50 years is a long time ago. My first Mopar was in 72' (a Dodge Sportsman Royal Maxi B-300 Van) and I just 3 years ago, put it to rest. Still have the 70' 340 that I have installed into it and saving it for my next project. Pittsburghracer, I do agree with you, "Mother Mopar or any other large manufactures doesn't care about the past, but only for today, not even the future. The days of buying a part for anything are over. They want to sale you something new. The EV cars are an example. Ten years they will be trash and then you must buy a new one.I’m curious to how old you are. Most of us older guys no that mother Mopar doesn’t rally care about us. They are kinda stingy about sharing thing like engine casting blocks.
Are you talking about the Winkle? I had a R2 and R3, they were lots of fun from a roll. Just need to watch the temps.I have a few R3s stashed away, otherwise I would defiantly be using the Ritter block for my w8/w9 stuff.
True, if you are restoring a car, but as a good sleeper, why not?Most guys want a 340 because it says 340 on the side of the block. Sleeves wouldn’t accomplish that
I don't know how thick is a sleeve is but you would have to bore a 318 0.130" + whatever the sleeve is make more sense to sleeve a worn out 340 block or Just bore a 360 0.040" and get some crank spacers for 3.31". or just say your 340 stroked to a 367.I'm no expert on this topic, but why could you not sleave a 318 block with 340 sleaves?
i don't know where you are and what machine shop rates are like, but sleeving a 318 out would rapidly approach and likely eclipse the price of a 340 block. probably be damn near the cost of an R block almost by thenTrue, if you are restoring a car, but as a good sleeper, why not?
I have no idea what you are talking about.Are you talking about the Winkle? I had a R2 and R3, they were lots of fun from a roll. Just need to watch the temps.
