Search feature here is pretty handy, and right dandy. Have you tried it yet? Hours of reading and education free for the takingAnyone ever hear of SPEEDMASTER aluminum heads good or bad ? Found a pair of new ones for a good price.
Using my Samsung phone made in South KoreaNever answered where your computer was made?.....
Ive found my Pro Maxx small block CNC ported heads to be really very very good. Disassembled checked out good to go. I personally modified the spring seat for different springs.Anyone ever hear of SPEEDMASTER aluminum heads good or bad ? Found a pair of new ones for a good price.
Just a FWIW.... Cawley did. Not Tony.Well I really dont care about your money
You asked and I told ya
Lighten up
My mistake I will edit past post.Just a FWIW.... Cawley did. Not Tony.
Wrong attitudeQuality cleanup and a little paint, an engine don't know or care where a cylinder head is made.
Performance is the only thing that matters. lol
I think some people's budgets you just can't change.... It really does come across as if you're telling people how/where to spend their money...Wrong attitude
"some people you just can reach"
Keep talk'n it creates awareness.
"" speedmaster heads are made in china"" Where do you think edelbrock heads are cast?
California...."" speedmaster heads are made in china"" Where do you think edelbrock heads are cast?
What crime pay out all that money and you have to rework new heads.the earlier procomps had problems
get the speedmasters bare and pick your parts
edelbrocks spotty qa is well documented- you have to rebuid them
Nope I am wrong. Cast in So California....they are cast in China for sure
I have a pair of Speedmasters and they look pretty good. It has been written and posted hundreds of times that any new head you buy should be checked out before you pull it out of the box and bolt it on. Just my take on the subject.What crime pay out all that money and you have to rework new heads.
I guess you get what you pay for. Wouldn't a fella would be better off just to buy better heads rather than buy the cheap heads and add the cost of making them right?
Sounds like I've got the same heads as you but I just got mine back from the head shop. The machinist said that the CNC porting job looked pretty good but the valve job was ****. He said it looked like they did a 1 angle valve job and that the cut was pretty far back (deep?). The spring rates weren't very consistent but usable. However, I'll probably have to shim springs maybe .030 to bring the pressure up a bit to match my intended cam. I also had an intake and exhaust port flowed. Results match up pretty well to what others have posted with the intake topping out at 274.Dropped off a set of the CNC speedmaster head for a new valve job....These were a complete set with valves and springs from Speedmaster. Asked the guy to upgrade the valve job,,,,,lol
And the valve springs are going to replaced and he will flow bench one port.....4 to 6 weeks....
Yep. Like everybody says. he price is right and with a little work can be made into some pretty good heads. I started a thread with links to all the Speedmaster head threads. Some good stuff in some. Speedmaster head thread indexSounds like I've got the same heads as you but I just got mine back from the head shop. The machinist said that the CNC porting job looked pretty good but the valve job was ****. He said it looked like they did a 1 angle valve job and that the cut was pretty far back (deep?). The spring rates weren't very consistent but usable. However, I'll probably have to shim springs maybe .030 to bring the pressure up a bit to match my intended cam.
